I'm going to replace all the bearings since i can't realy see any thing wrong with the gears or any thing else, but i feel realy strong about the whine coming from the tranny so since I have it out and apart I should do what my gut says.
T20
How much wear should you see on the out put shaft from the shift collar?
If yours has wear, and you are hearing a whine, I wonder if you have something bent?
I believe I found the whine in the transmission, the input shaft bearing fell apart as I started to remove it from the output shaft, the needles had worn to a point on the ends on all of them, they got damaged from the contaminated oil from the guy before me not changing it ,also i was making a tool to replace the sun gear bearings when the gear i was using to check the tool for fitness the bearings started to fall out of it so I got another one to finish the job. When I looked at the bearings I couldn't see anything out of the normal.
