Originally posted by john swenson
View Post
Yes, there are three bearings on the outside of the box. the side of the box will bolt to the frame/tub where the original axle bearing would have been. I made stub axles to go where the original axles would have been to power the top sprocket. the original axles will go in the lower bearings/sprocket. I did have to shorten the stock axles. So now you know I did go with sprockets and chain inside the boxes with the lower bearings able to adjust and take up slack. the boxes will be sealed with oil in them.
Mike.
