Max IV project
  • Max IV project
    Is it a Maxargo or Argomax?
    Acta non verba
    Nice!
    Hey man, empty your mailbox.
      Mail box is empty . thanky you
      Acta non verba
        you tell us! Argo trans in place of a T-20, or just Argo style bent steering levers with a hand grip parking brake setup?
          Yes, fill us in on the details.
            The only way I would do a T-20 swap is to put it in an Argo. I wanted to get rid of the mechanical calipers on the mid mounted discs and floor mounted hand brake and replace them with a pair of hydraulic units I had around. Also wanted to move the laterals over to make room for the passenger. I put the controls on the right side to balance out the engine on the left. This project started because the tub had a hole in it.
            Other mods completed with Photos to follow:
            Acta non verba
              What tha'. Heyyyyyyy.
              This is all I've got to say about that.
              Bridget
                Looking great there Mark, is this the machine that Tom has been driving?
                  Yes, its the machine Tom Z was driving. New lower tub with front, middle and rear skidplates. Argo axle seals. New splined rear axles and sprockets. new middle and front pinned axles with inboard locking collars. Old style popsicle stick trans with heim joint for the controls. Maybe do a split shift. This rebuild is for the long haul. The Leaking hull and Busco mud just killed it.
                  Acta non verba
                    Mark,
                    Any pictures of the middle skid plate, also your brake set up?
                    Mike
                      Hmmm... nice looking Margo!
                        Additional photos of the laterals and skid plate mods.
                        Acta non verba
                          Very nice!
                            Photo of hydraulic disc brake conversion from lever actuated mechanical disc calipers.
                            Hydraulic line not connected yet
                            Acta non verba
                              jerseybigfoot,
                              very nice work.
