Marc. You where a little quiet for a while. I've been wondering what you have been up to. This explains it. Hello R.I. you out there? This is a REAL brake system. Take some notes.
Max IV project
Nice work Mark. I've been considering a middle skid plate as well as Argo type laterals. I'd not though of moving them with a Hustler type mount good thinking. I especially like the split collar and argo flange conversion"Don't worry my Dad's a TV repairman, he has an excellent set of tools..I can fix It"
Originally posted by mark m. View PostThis is a REAL brake system. Take some notes.
On my RIM, they are basically a brake disc on a shaft with no bearing; only a bushing. They floated side to side quite a bit, and were only held "straight" by the caliper. And, boy do they really spin! RI did have a good set up, but looks to be done as easy as possible. With the addition of hydraulic calipers, and if you can put an insert bearing into each disc and C-clip it in place, it'd be tons better than the orignal design.
~msigpic
Mike you are correct, this is the early max setup with the mechanical units attached to the frame rails. A little Busco mud and the mechanical brakes were frozen and impossible to get to. Changing pads will be a 5 min job now. I used a non floating caliper with 2 pistons to center on the disc and should hold the disc centered. Originally the bushings just rode on the shaft. No grease port or way to lube them. I cross drilled the shaft and added a Zerk. I still have the bushing setup but replaced the sleeve bushing for a shoulder bushing. If the bushing does not hold up Ill machine the sprockets for ball bearings. The hand brake has a parking brake feature also. I did look at moving the trans forward but the brake sprockets on the center axles are the wrong spacing to make it an easy swap.Acta non verba
Looking great Mark!Life should not be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways , cigar in one hand, whiskey in the other, body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!!!"
