Max IV project
  • #16
    Marc. You where a little quiet for a while. I've been wondering what you have been up to. This explains it. Hello R.I. you out there? This is a REAL brake system. Take some notes.
    • #17
      VERY interesting. Looks more installer/repairer friendly than the T-20 output shaft mtd.discs that I'm currently working(fighting) with. Thank you for sharing this Marc.
      Joe.
      • #18
        Nice work Mark. I've been considering a middle skid plate as well as Argo type laterals. I'd not though of moving them with a Hustler type mount good thinking. I especially like the split collar and argo flange conversion
        • #19
          Minus the hydraulic calipers, this IS an RI brake system. RI had this setup (with mechanical spot calipers) on the original RIMs and Max IVs. They did a great job of breaking, but they needed an aweful lot of refining. I bet Jersey has already accomplished most of the necessary updates, though.
          On my RIM, they are basically a brake disc on a shaft with no bearing; only a bushing. They floated side to side quite a bit, and were only held "straight" by the caliper. And, boy do they really spin! RI did have a good set up, but looks to be done as easy as possible. With the addition of hydraulic calipers, and if you can put an insert bearing into each disc and C-clip it in place, it'd be tons better than the orignal design.
          ~m
          • #20
            Mike you are correct, this is the early max setup with the mechanical units attached to the frame rails. A little Busco mud and the mechanical brakes were frozen and impossible to get to. Changing pads will be a 5 min job now. I used a non floating caliper with 2 pistons to center on the disc and should hold the disc centered. Originally the bushings just rode on the shaft. No grease port or way to lube them. I cross drilled the shaft and added a Zerk. I still have the bushing setup but replaced the sleeve bushing for a shoulder bushing. If the bushing does not hold up Ill machine the sprockets for ball bearings. The hand brake has a parking brake feature also. I did look at moving the trans forward but the brake sprockets on the center axles are the wrong spacing to make it an easy swap.
            Acta non verba
            • #21
              Looking great Mark!
