So, I'm confused.
You're running the single-tube sprocket assembly on the back axle (an upgrade from the two separate sprockets that were set screwed to the axle individually- they were snapping splined axles for a while, Jay said...). Two set screws hold this tube in place on the axle. The set screws don't just screw down to the axle to hold the tube in place; they screw "into" a hole on the splined axle. This is probably a silly question, but can you verify that the sprocket tube is lined up on the axle so that the screws are screwing into the axle, versus just "against" the axle to hold it? I've made this mistake putting the racers together, so I was just giving it a thought.
The biggest problem with the set screw style is that it's not that hard to break set screws, at which point your tube can slide to either side and cause the alignment problem (hence RI's upgrade to the snap rings) Two split collars, one on each side of the tube, will help a great deal, like Mike says. They're cheap, and a cinch to install....
