i would guess about 850kg
Homemade 6x6 with 3 cylinder motor
Originally posted by chris davison View PostHi kelvin That sounds like 1874 Lbs or so. Do you have any way to weight it once done? Are you going to try to propel it with tires only in the water? and I think you should go with 36" tires or 900mm in dia with your clearance and gear ratio. now that would be some ground clearance.
And great floatation too!
For tires check into HUMVEE surplus tires. Got a cheapo track desighn I'm thinking of. After final exams down (this week) ill ilumanate it.
I know your in austraila.. But take a look at this and drool. http://item.mobileweb.ebay.com/viewi...id=07321252387Last edited by spookum; 05-07-2013, 03:31 AM.Alaska floating atvs group on face book. Fixing help and trail rides!!!!!
ATV = Alaska Terain Vehicle
That thickness of aluminum is not really that thin. I dont think you will need many ribs and even if you do weld it go ahead and silicone it to the metal frame every where it rattles. also if the welds leak you can hit it with a center punch and that will stop small pinhole leaks. I had no leaks in the welds with 3 passess of a spool gun on all fillet welds.
I had to go back and look at the last picture you posted to make sure I was still looking at the same frame. It looks completely different now that it is painted.
