amphicat retore under way
  • #31
    still doing work..
    cleaning the trans and re greasing it up be ready to go back together soonphoto(36).jpg
    • #32
      my dad got the hubs axles and sprockets i needed to be reused cut down till i decide to change to a larger motor( maybe the kohlers 25hp and t-20)later down the road
      axles photo(37).jpg almost done i did reuse the 3 bolt hubs because im going to reuse the stock wheels and tires for now.. this project was suppose to be on the cheap and i kept adding to it...
      • #33
        worked on getting the drive clutch setups all cleaned and re-greased photo(42).jpg
        and then test fitting all the axles sprockets get ready to make holes photo(44).jpgphoto(43).jpg
        • #34
          Looks great.......very nice work!
          • #35
            Thank you hope to be able to ride soon few weeks maybe
            • #36
              Great work. Really inspiring me to get my arse into gear and sort my amphicat out.
              • #37
                cant wait till i can ride it.. it was fun before but it would always break after 30min of ride time or less
                • #38
                  some more work..
                  had to modify the left lateral to clear the new bearings photo(48).jpgphoto(47).jpg
                  turned out pretty good photo(49).jpg now if its gonna work i guess ill see once its more together
                  it is getting close but i gotta figure out something for chain tensioners photo(50).jpgphoto(51).jpg
                  • #39
                    been a while since ive updated done a lot since i have
                    working on getting chains all test fitted and some work of the custom chain tensioners
                    • #40
                      more work
                      axle fitting, i did also extend the axles an inch more from the stock size so overall it 2inchs wider.. and yes i know you guys will hate me but i bed linered the bottom 1/2 after the abs repairs.
                      • #41
                        few more
                        getting close chains all setup in tub everything is bolted in.. i haven't sealed the outer bearings yet.
                        • #42
                          Looking good!
                          • #43
                            took this thing for its first ride last night rode for the longest ever 30min lol.. still gotta work on the brake system think im gonna convert over to a motor cycle brake system to have easier time controlling it, i already have 2 matching calipers just need to figure out 2 good master cylinders to setup and fit.
                            • #44
                              Originally posted by thenewguy View Post
                              anyone have any suggestions on what to do so i can upgrade to 1 1/4 axles to seal water out? the last pics i posted are suppose to be the water seals but... theres no way to run an 1 1/4 axle thru them
                              Argo use a lip seal and bearing carrier for their older machines with 11/4"axles. Most dealers replace them and you can get them cheep. Replace the lip seals and you have nice upgrade.
                              Acta non verba
                              • #45
                                im kind of passed this point... and decided its not gonna be that big of a deal to stay out of lake type water.. but by chance you have any links or anything so i could get an idea what your talking about
                                thanks!
