And now continuing on from where we left off
Ah clearly this came off from about here
and kinda sorta in place
So this appears that a 3 bolt flange was welded to a sleeve that was welded to the alxes' end, this is factory and as far as I'm concerned clearly not strong enough for the punishment I dish out!
So this weld here
Should also be here, along with the plug weld on the end, and maybe even a plug weld in two spots through that sleeve onto axle
Then the whole assembly bolts to these adapters, which when added to big grippy tyres created a tremendous amount of force and well....is it really any wonder why that weeee little weld broke based on the abuse I dolled out?
So now I'll work on getting it all back together and welded up then thoroughly inspect the other 5 axles and weld the sleeves to the axle as well.
yuppers that's a broken weld
I'll likely grind out all that schmeg weld there inside the sleeve after some measurements for location
That would enable me to re-weld that sleeve onto the end and circumferentially around the sleeve
That should be enough to make it strong and safe and hope it wont break again. Once I get going a bit further with repairs I'll for sure post more info
Thanks for looking
So this weld here
Thanks for looking
MUSCA TUR BOTA then eh?
just when it's proven itself to be a decent machine!
