Do the Florida races start this winter or 2017???
2016 race rules
We're all reading, great to hear from you. Was going to direct you to the North Carolina race if it gets a turn out.
What part did you end up in?sigpic
Originally posted by frabbit View PostMight have to battle a bit to get in the racers againsigpic
Can someone explain this to me a little better? I just want to make sure that I am doing it correctly. Thanks
"Belts must be attached directly to the frame or in the same area of vehicle as the roll-bars and on a plane parallel to the bottom of the driver’s seat, or lower. Please make sure that any excess belt be cut off or taped up so it DOES NOT get caught in the chains.""Racing is life. Anything that happens before or after is just waiting."
I was thinking the same thing, Marc. If the seat moves and the belts are mounted directly to the frame, it'll eventually start to hurt.Stuck in the seventies- not in the swamp.
So, "Do It- Do It", seat belts mounted to seat frame with limiting straps of safety material.
That's done for tech inspection. PHEW!sigpic
