6x6 Racing Results 2009
Originally posted by Mike View PostHere is Saturday's stock 4-stroke heat race that includes Marc's rollover. I asked Marc for permission before I posted it because it is a little graphic. The race was red flagged due to his rollover and then we started back up about 45 minutes later. Luckily Marc is doing ok now.
I rolled at the same time that Marc did so when the race was restarted I got a second chance. However, Lewis was in the yellow spider and I just couldn't catch him.
YouTube - 4 stroke heat race
Thanks for the excellent video.Acta non verba
Glad you're ok Marc.Banned
Marc glad your up and running again. You gave us a little scare there. Hope to see you at Busco with all you wit and humor!I brought you some Cheerwine but with all going on i didn't get to give it to you. I'll make up for it in Busco. See you later.
40 chain
Originally posted by Joe M View Post40 chain would of been the first thing to go, but it held up great.I break the shear bolts on sprocket tubes and hubs before the chain brakes. Never had a new 40 chain break, just old rusty ones from the machines when I get them after sitting 20yrs.
Which I would recommend not to use older ones as when the break, they wrap around sprockets and will crack the lower tub 1st gen attex's anyways
I cut a strip of plastic and lay it in the chain channels to help in case it does break and I dont know if it helps yet to protect but seems like it would.
If you got an older fixer upper machine. Its a good Idea to just replace them before you run it.
As always George great video! Loved the in car cam shots. There are so many video and they are all great!
6x6 worldLife should not be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways , cigar in one hand, whiskey in the other, body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!!!"
Great videos Mike!!!
That powder Puff race was one of the best!!!!! I am thinking there will be additions to the Air Bud wall of Whipper's. A lot of them being the ladies!!! Kudos to the ladies!!!!!
Mike that Max is a great running machine. Kudos on the win, your one tough competitor!!!!!Life should not be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways , cigar in one hand, whiskey in the other, body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!!!"
