Sorry, all I'm doing there is turning the engine over by hand, the screwdriver is touching the top of the piston. When the screwdriver stops moving, I know the piston is at TDC (Top Dead Center)
Seafoam will work fine. Another option is to add a little ATF to your fuel. Automatic Transmition Fluid, 1/4 to 1/2 liter to a tank.
The valves will only start acting up if you run old fuel or have water In your gas.
