Got another reefer at lunch today. Half the hours, and a newer unit! Same engine. Will spend some time tonight and tomorrow tearing into it. I'm sure there will be a few more pics.
Diesel in a Magnum 8x8
making me jealous you are....but that's ok, I know how much work you have ahead of you buwa ha ha ha ha...good luck can't wait see some serious fab workMUSCATEER 6x6
MUSCA TUR BOTA then eh?
94 F350 4x4 7.3 IDI ZF 5sp
Al "Camo pants"
Some new eye candy tonight! Spent the evening in the shop at work. Makes life easy because we have a crane. Got the engine out. Cleaned up all the bracketry. Will have to make all my own engine mounts. Will save the rubber iso's and reuse. They're pretty beefy. Though I can get new ones cheap through work, she who must be obeyed mentioned not spending too much on toys. I need to sell a few bikes first.....
Anyway, moving on. All the ideas are starting to turn in the old noggin. Won't bother boring you all with them right now. So, here's some pics. Get a load of that oil pan!!!!!
Originally posted by Rudy_Magnum View PostSo, here's some pics. Get a load of that oil pan!!!!!
Cool engine Rudy. I have the same engine out of a ThermoKing that I'm still unsure what to use in. I also picked up a Kubota V1505 out of a Carrier Transicold that I'm using in a Newt the Bold. It's about a 250lb engine, and I think most of that is in the pan. I was originally planning on swapping out a smaller pan, but this way I can change the oil once every 10 years.
Wholy Schmolly that's a pan alright...wowzers!
Looks like quite a beast to me should be plenty of torque to make yer argo move right along.
Whats the top governed RPM available to you that you know of?
Any plans on a turbo, say RHB 31 Mitsu? ROFL...nothing like excess right?MUSCATEER 6x6
Al "Camo pants"
These engines in a JD 430 or F-935/F-915 were rated 20-22hp, and 35-37ft.lbs. of torques. Should be OK. No plans for a turbo yet.
The speed on a thermoking is somewhere around 1800-2200rpm. Not a lot of adjustment. This engine in a JD tops at 3650rpm. That should be plenty fine for me. I am looking to get a governor from a F-935. That comes with the fuel shut off lever, as well as a full range throttle lever. I think the actual governor is different too, but the injection pump cam is the same. This is my first diesel that I'm working on, so there's a bit of learning to do.
Accomplished a bit so far this weekend. Took the scrap away, made $351!!!! Woot!! Started tearing into the beast. Got 7 of the wheels off. One wheel has some water in it. The 20" I was gonna use as a spare has a hole the size of a fist torn in it. The rest are all 22", and some of them are looking a little sketchy. One or two are getting badly cracked. I'll have to keep my eyes open for a deal on some used ones. The front right wheel didn't come off because the studs spin in the hub. Yes, all five of them. A bunch of other studs are slightly loose, so I'm thinking that I will just replace them all, and get all new lug nuts. Anyway, some pictures for you guys.
I measured things up again, the diesel will fit in there without making a hood extension. Even with the monstrous oil pan! I did a bit of looking on eBay and found a few small radiators. The original one for a 430 and F935 is about 14" x 17". The radiators I found are 7" x 14". So, I was thinking I can stack two of them and get roughly the same amount of cooling. I will put two 7" reversible fans on them, and it will all fit in the heat outlet area in the hood. Should work out alright. Will take a bit for the stuff to come in, but in that time I still have the rest to do.
Worked most of the afternoon today, as its a holiday Monday up here in the north. Got another axle out, then decided the front axles would be soooooo much easier if the engine was out first. So, took steel ring off, drilled all the rivets out and split the shell. Unbolted engine and pulled it out. That's about as far as I got before the wifey called me home for dinner.
Pics:
After looking at the parts manual, and thinking about it for a bit, why would my rig have three bearings on the front and rear axles? There is an inboard one, one on the inside of the shell, and then the one in the end of the aluminum housing. Seems a little silly to have three bearings on a shaft. The parts manual says that there is only supposed to be the inboard one, and the one in the end of the aluminum housing. Any thoughts?
looking damn good keep the updates coming...
Btw...whats that torched off plate in the one picture at end of tub?
Can't speak to bearings...know less than you about argo except they are aatv's lolMUSCATEER 6x6
Al "Camo pants"
OK, done a bit more tearing. Found out a few things. The aluminum holders on the back axles were added by a previous owner. There was three bearings only on the rear axles. Whoever added the aluminum bits just left the original outer bearing stuff. Aldo, since the frame wasn't set up for the aluminum holders, the threads aren't there, or the round tube like at the front. So, the furthest to the rear bolt is just siliconed shut because it would be right in line with the rear part of the frame. Not a bad job really, I guess. But, should not have left that third bearing. From my experience, three bearings is not better than two.
As well, the axles on the right side are newer style, with the 1" inner bearings and thrust washers. Boy, are these a pain to get out!!! Whoever put them in put the bearings in backwards, so the set screws are inside the C channel. They didn't use antiseize, so now they don't come out easy at all. I have to fabricate a beating block so I can pound them out with a sledge. Not fun. But, I like this design better. Will be machining down the other axles and tapping the ends for bolt and thrust washers.
Not much on the diesel yet. EBay tracking says governor should show up sept 11. Hope so. Very close to ordering radiators and fans. Just gotta measure a few things first.
I'm excited to take that first drive when its all done. Will make all the work worth while.
Success! All axles, shafts and bearings are out! Gas tank is out. Seat frame is out. Only thing left is bearing carriers and hitch bolts, then the frame comes out! Woohoo! Calling it good enough for the night. Gonna grab a pumpkin spice from Timmie's, and pick up the wifey. Tomorrow should see the frame out, and in the truck to go get pressure washed and degreased. Woohoo!
