Diesel in a Magnum 8x8
Don't go cutting down those axles without some measurin, the stepped axles are slightly longer than the older ones.
Place one stepped center axle in and tighten everything and use that as a baseline from body to hub flange.
Also if there is room try turning the rear ext.s to the front and check bolt clearance for the other 3, maybe mount them that way. (support is support)sigpic
Hi Jim. I did notice that about the axles. Don't you worry, all will be done right. I am taking everything to work tomorrow to run through the parts washer. If the axles won't fit in the lathe at work, I guess I'll have to send them to the machine shop we use all the time.
Got the frame out of the tub tonight. Found some tools buried in there from a previous owner. Some sockets, wrench, screwdrivers. Some of them good still.
Front/rear axle supports were a real pain to get out. Steel bolts in an aluminum housing, no anti-seize, with water commonly around them. They don't come out nicely. One bolt stayed in the housing, we just turned the housing out.
Hope to get bearings and seals on order this week or next. Frame will get cleaned up, painted, and a few modifications done. Makes it tough to do this project right now. Can't do it at home, as we are selling our place, and we are moving the shop at work in a week and a half. Might have to take it a bit easy for the next bit, at least in fab work.
Anyway, time for bed.
Spent some time at the shop tonight. Got all the axles apart. All bearings are off, tied all the parts from each shaft together. Labeled everything. Was quite a mixture of bearings. Some original style Argo, some good replacements, some bad replacements, and some that were wrong sizes. Nearly all the ones with locking collars were wrecked. The eccentric part of the inner race was usually snapped off. Makes for a fun time trying to disassemble. Had to cut a few, and press a few. Actually had one bearing (Argo bearing) that the outer race was shattered. Don't remember what wheel it was, but the bearing holder was keeping it together.
Pounded out all the wheel studs. A lot of them were loose, especially the front and back axles. Will replace with new ones, hopefully with bigger knurled sections. Will get new nuts as well, and antiseize them when I put them on.
Compared newer axles to old ones. There's about 1/4" max difference in length. Don't think that's gonna make much difference in the grand scheme of things. Will still get Ryan to match the new ones when he turns down the old axles.
Next step will be to order bearings and seals, studs and nuts, and get this all going. Don't know how long this will take. We are moving the shop next weekend, and I've got 4 big projects on the go....
Hope to be firing a diesel up soon too.
Wow you sound as busy on yers as I am....
Keep a photo journal of it all is all I can say...post it here..then you can referr back to it when needed.
Thanks for all the updates.MUSCATEER 6x6
MUSCA TUR BOTA then eh?
94 F350 4x4 7.3 IDI ZF 5sp
Al "Camo pants"
A bit more work done tonight. Tried getting the primary clutch off the magnum tonight. Got all the parts off, but the last one (stationary part and shaft) would not come off. So, took engine off plate. Washed everything, and pulled out the yanmar. Set it up there to have a look and see how things fit. I think it will fit OK.
While I was looking things over, I noticed that the bearings on the transmission output shafts are loose. The left one is pretty much wrecked. The disc flops all over the place. So, I get to take the secondary clutch off now too, and get a few more bearings. Yay....
hi
A suggestion [it may have already crossed your mind ] Due to the increased horse power and torque ,would u consider a transmission overhaul?? Particularly as u are finding the disc /output bearings worn out. Does your tranny jump out of gear or have any operational issues?? Reverse idler and or the layshaft can be worn on older units .
tomo
Massive is all I can say compared to the trans rofl.
Keep it coming. your journey has only just begun and will continue for many many more hours and pictures!MUSCATEER 6x6
Al "Camo pants"
