Since its a holiday up here in canuckistan, I thought it best to get something done. Chopped down all my blades of grass this morning, then it was Argo time! Put the tires on the rims, which were freshly wire wheeled and painted. A jug of bead lube, some valve stems, a few ratchet straps, and I was in business. The loose tires I got had obviously been sitting around a while. Since 2009, if you go by mfg date. The beads were almost touching each other when I picked them up. I used spray paint cans to spread the beads for a few days.
This is what the beads looked like after.
Not awesome, but better than before.
So, I spooned them on with copious amounts of lube. If I can put it on with my hands, then you know there's enough lube on it! To get the beads to seal, I had to use two ratchet straps. You can't just use one. You need to have two at 180° apart. Cinched them down real good and threw some air at it. Worked awesome! Easiest tires I've ever done! Put a bit of air in, then let the straps go. Don't be anywhere near the line of fire when they go, you'll find out its not so pleasant. My beads seated anywhere from 15-20psi.
After about 2 hours work, all 8 wheels are ready to go on. With the exception of one, all are under 24" diameter. I think the one that's bigger is inflated too much. Aired it down, but forgot to check again.
MUSCA TUR BOTA then eh?
