Jersey,
No I don't have a T between the pump and the carb. Looking at the tank, there was no place to even run the line back in that was plugged or plated. I'm assuming something was actually stuck in the line. I didn't see it but it must have cleared when I pulled the fuel filter off.
Larry,
I always seem to have to choke it full for a second and then it fires right up on half choke. When I was studying the manuel I figured out that the choke should actually hit the throttle on the carb and fully open it when the choke is all the way pulled. If you tee your line and put in another petcock in the tank, let me know if there is a difference. I'm not sure it will be worth splitting and resealing the tank, but if something amazing happens like easy idling I would consider it.
Larry,
