it does look like jjorts tracks have a lot of extra room on either side of the sidewalls, which is primarily going to allow the track to move side to side (the main concern is getting close to the tub)....so I would be concerned primarily about belt/tub clearance. But my opinion is that with adequate track tension, they should still work just fine, and he should have no issues with walking out of the tracks. This doesn't sound like one of those scenarios. The channel guide area is very shallow, but it's not that big of a deal. Anytime you drag/skid/roll an unweighted track over a ledge, it can easily get pulled off. It's one of the "watch-out" scenarios. It usually has to be a very steep bank that you are straddling if that makes sense. But a little slop side to side in a channel crosser shouldn't cause big problems other than the track moving closer to the tub.
I'm with Old Tucker- A wider tire would be more preferential (and it would prevent some rocking), but don't feel obligated jjort to go change out your tires. If I'm understanding you correctly, I am fairly certain as to why you got to throw one of your tracks in the back of your machine...sorry man!
... climbing out of streams where you are floating or one side is floating and the other grabs is really tricky... I actually had water coming over the side at one point (I had to use the bilge pump) had some crazy angles happening. I am really not surprised at all that I came out of the tracks.
