Hey Riotwarrior, I'm a fan of thinking outside of the box and not picking on you or anyone here. So I appologize if I may have offended you. I am and have always been an armor fan, fascinated with tracks. When I worked construction I could watch the bulldozers and excavators all day. Before my kids were born my house was sort of decorated with tank models I built, much to my wife's dismay. The tracks are one of the biggest draws for me with these aatvs,I have two sets, Argo supertracks and a set of Adair belted. I consider them my deep snow and everyday tracks. My experience is limited to my local snow conditions, so I can only speak for me. Two years ago we had a blizzard here and I super tracked up for the first time. I found no issues with the argo climbing right up and on top of the 3' burms plowed up on the side of the road and staying on top of the snow. I actually fell getting out of the argo twice forgetting that it was sitting on top of the snow as opposed to pushing it. As I stepped off the track to the ground my lead foot would sink into the snow and cause me to loose my balance. I guess this comment is more directed to oldtucker and the lead angle of the track allowing the machine to get on top of the snow. I think the combination of light weight and tire / track diameter at the front of the machine allows for the climbing on top of the snow. That Tucker I would think is heavy considering the foot print of the front and rear track sections possibly causing some difficulty of getting on top of the snow. I haven't tried the Adairs in the same snow depth conditions but think the open space of the track design would limit the floating capability as it is all about surface area.
Now the original issue of suspension, it's the only flaw I can find with these aatvs. we are limited to tire bounce unless a suspension kit is installed at a penalty of width, which may or may not be a factor for some but won't work for me where I ride. Of the two suspension systems I've seen video of, I think whippers is superior to the one someone in Canada designed for Argos, speaking from a 6x6 point of view and not the 8x8. Whipper's system seems to give better travel per axle. On that note the Max with the springer kit and the adairs seems the ideal combo to marry the two ideas of track and suspension. It also seems to give enough play in the suspension while not compromising the track capability that Noel was hinting at. A track itself has a certain diameter to it, which will ultimately limit the amount of travel any obstacle can push on the track without lifting the entire side of the vehicle. I know I'm master of the obvious but I love tracks. I am certainly up for a solution that gives track capability, suspension and affordability for all. I'm also a very big fan of the K.I.S.S. principle, "keep it simple stupid". Beat the Germans and the Japanese in WW2, also has been a virtue of the venerable AK47. The current set up allows us to run tracks and at an instant pull the pins and drive off the tracks and run tires when tracks aren't needed. A system designed by Walter Christie in the early days of tanks and adopted by the Soviets for their early BT series of tanks.
After all this long winded rant if anyone is still listening, I'm leaning on a suspension system for the bench seat itself in my argo much like Keith Hill incorporated into his max4. It's an upgrade I would like to do in the future that seems pretty easy to do.
Riotwarrior keep us posted on the evolution of your idea you may reinvent the wheel/ track and that would be cool.
