Well after running Adair tracks which I consider to be easy on the drive train I broke a center axel at the sprocket. Very odd. Especially since the front chains were removed. So now I’ll be running off of just the back tires, kind of like the old track Max used to. I’ve run it this way before and it turned easier the only reason I left the center chains on is if Incase I threw a track I could still move. After running tracks on these things for over 20 years I’m now recommending rear chains only. Lessstress on everything.
Max IV track recommendation
tbone9 we remove front chains on the MAX 2 at the factory when we run tracks. But in your case your axle snapped at the snap ring groove by the sprocket. This is a known issue with snap ring groove axles. We have new MAX 4 axles in stock that do not have snap ring grooves (we use shaft collars to hold the sprocket in place. If you need something, just let me know.
Andrew
- Likes 1
I’m still surprised how a center axel with no front chain’s turning inside of tracks in snow only could break. I’ve already swapped out all for corners for the lock collar type. Way easier than snap rings. It’s hard to believe that the 1 1/8” diameter snap ring groove weakens it that much. Especially since The axel is only 1” solid after it’s splined. I wish these were made with several small splines like automotive shafts instead of six deep cut splines. This would allow a bigger solid diameter and more spline engagement for more contact and less wear.What it lacks in ground clearance it makes up for with traction.
