Well after running Adair tracks which I consider to be easy on the drive train I broke a center axel at the sprocket. Very odd. Especially since the front chains were removed. So now I’ll be running off of just the back tires, kind of like the old track Max used to. I’ve run it this way before and it turned easier the only reason I left the center chains on is if Incase I threw a track I could still move. After running tracks on these things for over 20 years I’m now recommending rear chains only. Lessstress on everything.
Max IV track recommendation
tbone9 we remove front chains on the MAX 2 at the factory when we run tracks. But in your case your axle snapped at the snap ring groove by the sprocket. This is a known issue with snap ring groove axles. We have new MAX 4 axles in stock that do not have snap ring grooves (we use shaft collars to hold the sprocket in place. If you need something, just let me know.
Andrew
