T20 trans fluid
  • T20 trans fluid
    I have been reading posts here but Im still a bit confused my first question is I believe my maxII is a 1997 what fluid works in that year model t20 trans and also when you drain the fluid do you let it drain into the tub of the machine then pull out a drain plug on the body to get it out? I was confused by the way some guys mix anti slip why not use it strait and when you refill it with the right fluid it said in a post to remove the drain plug until it runs out that did not make any sense to me
    Most of the answers can be found with the search:
    Don's post here describes what fluid to use and how far to fill it up: http://www.6x6world.com/forums/trans....html#post2315
    The purpose of the limited slip additive (Do not use it alone just use it as an additive if you like): http://www.6x6world.com/forums/trans...e-yea-nay.html
    Here is how you can change the fluid in your Max IV: http://www.6x6world.com/forums/max-a...fluid-t20.html
      service trans
      i use and vacuum pump from tooltopia.com their about 80 dollars and suck the fluid out from the upper plug and pull the lower plug and fill to that level
      i also use mercon semi senthetic oil last 20 times longer..
        fluid
        i used 1 quart f type tranny fluid minus the the four ounces of limited slip i put in works fine for me
          thank you guys that should be fine its all new to me right now thank you
