I have been reading posts here but Im still a bit confused my first question is I believe my maxII is a 1997 what fluid works in that year model t20 trans and also when you drain the fluid do you let it drain into the tub of the machine then pull out a drain plug on the body to get it out? I was confused by the way some guys mix anti slip why not use it strait
and when you refill it with the right fluid it said in a post to remove the drain plug until it runs out that did not make any sense to me
