Originally posted by msta999
View Post
Just bought a used 2018 Avenger 8X8
I’m new to this site and Argo. Quick answers don’t happen unfortunately. It’s a slow response on the forum. From what I see and read some guys know there stuff. Gotta be patient unfortunately. I would try n get your answer anyway you can and not solely relying on forum. Good luck. Wish I could help ya. Good luck with your new machine.
Timken makes very high quality products, if you are shopping for chains most manufactures will give and rating on how many pounds per a square inch they can with stand. Here is an example:Originally posted by msta999 View PostAnyone ever heard of this chain? I know Timken makes good bearings.....
Find all the bearings, bearing housings, v-belts, oil seals, collars you need and more including the #60 Roller Chain at theBigBearingStore.com
You can see here the Timken has a better rating
The higher the rating the better the product, you can find them a surplus warehouse, EBAY, Amazon Etc, just look for the best price and the highest rating.
correction,the chain is made by RBL http://www.rblcanada.com/products.html
they make a decent axle bearing for our argo as well.
Originally posted by plott hound View Postcorrection,the chain is made by RBL http://www.rblcanada.com/products.html
Check the link, these chains are only rated at 7227:
good info,i guess thats why the RBL CHAIN IS CHEAPER.Originally posted by mightymaxIV View PostCheck the link, these chains are only rated at 7227:
http://www.rblcanada.com/catalogues/...ller_chain.pdf
I think was mightymaxiv wrote is spot on. There are numerous threads on here with this very discussion, check them out make your own decisions.sigpic
Thanks Buzz, I removed the hinge and found it was crescent moon shaped a little and had a crack, so I got a new hinge and pin from All seasons Argo in Anchorage and 47.00 later I was good to go, (had to pay Kid Curry 38.00 to bring it to the valley) none of the holes had pulled through. Now I just need to figure out what to do about the sagging fender, rubbing on the tracks.Originally posted by Buzz View PostNo worries, I can get you squared away, I have lots of scrap rubber and have had to do this repair to factory rubber tracks. I have a pair of 20” wide buldoc rubber tracks outside the shop that had the hinges torn out as well (repaired). I sent you a pm. Need to make sure all tensioners are released before checking axle bearings as well.Last edited by msta999; 01-12-2022, 02:04 AM.
As far as the chain goes, put on the best you can afford. How many hrs are you putting on a year? Are you out in remote areas? Do you have resources to help you out if you run into trouble? I put the RBL chain on as I have low hrs on the machine yearly, never in remote areas, and the place where I worked used it on their higher end snowbowers. 6,7,8, ft. single , double auger, tractor driven blowers. Worked for those machines which were often commercial applictions. How often they had to replace the chains is unknown.
That is pretty much what I am planning on doing. I go out 4-8 times a year, I take what I think I might need to get me out of a predicament, because I go out by my self, lots of rope and tools. I have a little over 400 hrs on this machine, my second argo. my property is only 4 miles from the road, just deep swamp in areas.
