Didn't someone say, "make sure you clean the gears"? well I didn't look at the front one close enough, there was a bunch of stuff on it, so I pulled the chain back off and cleaned it and it went on a lot easier, though the front right chain is tighter than the front left chain....took it out for a drive and rechecked it and the right is still tighter....maybe 1/8th inch play, the left has a lot less than it had but is at about 1/4-1/2 inch play.
what do you use to clean out the oil from the oil filter, when you change it? When I changed the oil I had a heck of a time getting the oil filter off, then all the oil from the filter when down?? and is coming out on the left side runner or what ever it is called that the chains run in.
