Originally posted by plott hound
View Post
pulled the trigger on a conquest
cool beans dan67,that makes life so much easier.my argo service manual has no info on the older free floating idler sprockets,only shows how to install retaining clips on the newer style.was not sure if the set screws were supposed to be installed or not.
thanks man.
Originally posted by Dan67 View PostI took down the right side and my 2000 conquest the sprocket is free floating. The sprocket on the front axle is also free floating. The set screws on the bearings where all that was holding the idler shaft in.
so after a bout with some real bad chinese food,i got the axles all pulled.should have frame out of tub by 9:00 am saturday.last guy to work on this put red lock tight on the bearings.what a pain in da buttocks breaking them free.could not break one front axle bearing free,had to cut axle off with a sawzall.
Ouch red locktite that sucks,the fight continues,hey we were going to do Chinese at the big smorg in Barrie tell me thats not where you got the bout.NCTOriginally posted by plott hound View Postso after a bout with some real bad chinese food,i got the axles all pulled.should have frame out of tub by 9:00 am saturday.last guy to work on this put red lock tight on the bearings.what a pain in da buttocks breaking them free.could not break one front axle bearing free,had to cut axle off with a sawzall.
Thats cheating Plott,I have a ton of the factory blind rivets for that job,but I dont have the gun to install they are weird rivets if you want I will check and see Iam sure I still gotem if you can find the riveter.NCTOriginally posted by plott hound View Postheres a picture for tonight.it represents 7 hours of cleaning,spraying and painting.i cheated a little and left the frame in.did not realize the skid plate was riveted to the frame.just gave it a tremclad tune up to clean the frame up.
is ok mang,most of the paint from factory is still on the frame.you still have rivets for the tubs?man i shoulda listened to you and grabbed 40.didn't want to be gredy and take all your goodies.still got leftovers here for ya,and they quit meowing.Originally posted by North Country Tough View PostThats cheating Plott,I have a ton of the factory blind rivets for that job,but I dont have the gun to install they are weird rivets if you want I will check and see Iam sure I still gotem if you can find the riveter.NCT
Well you can always give people good advice but most never take itOriginally posted by plott hound View Postis ok mang,most of the paint from factory is still on the frame.you still have rivets for the tubs?man i shoulda listened to you and grabbed 40.didn't want to be gredy and take all your goodies.still got leftovers here for ya,and they quit meowing.
got ya covered on all counts,I have come to realize you need all the help one can give
On another note I thought you had to pull the frame for a repair this is why I mentioned the factory skid rivets,heck I wish I had a gun to do them they are kinda like very small huck fasteners,and they are tough as can be,thats one reason I never installed my skid plate on my Avenger.NCT
lucked out and got all the welding done without burning a hole in lower tub.idlers are installed plus all the inner bearings and flanges.Last edited by plott hound; 04-08-2012, 04:35 PM.
