Well, finally got the chain adjusters finished and ready to bolt in place. I had to completely disassemble the Hustler, which was good, because there were some factory welds that had come loose and I could feel the frame flexing. This was a good opportunity to fix those issues.
The goal with these tensioners was first to have tensioners that did not have to be re-adjusted every time I rode the Hustler, and to eliminate a lot of driveline shock created by a static chain tensioner.
In the picture where the tensioner is already installed, we welded additional cross bracing due to the factory welds coming loose, and attached the tensioner to the square tubing that we welded in. This tensioner will push up on the chain by simply loosening the bolts from the top. We welded nuts on the bottom of the tubing so that a backup will not be needed.
The tensioner that is just sitting on the trailer, will be bolted to the frame in back and will pull up on the chain by tightening the bolts, again, no back-up will be necessary.
I am pretty excited about all the changes I have made this time around....red clutch spring, correct belt tension, chain tensioners, and re-sealed T-20. A little cleaning up and painting on the frame, and I am ready to re-assemble.
BTW, I HATE the keyed axles on the center drive axle where there are three sprockets. They tend to get stuck, and I broke my hand two weeks ago by accidentally hitting it with a hammer when beating on them (It's ok to make fun of me, everybody else has!). I did find that on the axles with only one sprocket it is very easy to remove the outer flange bolts, all set-screws, pull out the axle until the sprocket is close to the frame, and use an air hammer through the outer bearing hole to remove sprocket!
Here's the pics..
Chain tensioners pictures from friends & fun photos on webshots
Here's the pics..
