The top and bottom should be bolted together. The only thing holding the frame into the lower is the 6 axles and their bearings and flanges. Remove the axles and the frame will pull out. It's not as easy as it sounds though. Axle removal can be a pain.
Max ii help
Might be worth drivin up to meet Drew, he could probably hook you up with a lower needing much less repairs.sigpic
Where is drew? I am in southern west Virginia no one around here is into the 6x6 so there is really no parts floating around. I figure a used lower tub will cost me around a thousand just for the simple fact that i have to drive to pick it up
Don't underestimate the power of will when it is at its best
This weekend I'm busy in PA. Saturdays typically are not good for me right now with my kids sports and activities. I go to Akron every other weekend though and may be able to meet later in the day next weekend.Originally posted by farmboy View PostCan i come pick it up saturday? Do you think it will ride fine in back of a f250 or do i need to bring a trailor?l like to buy stuff and no I don't do payments!
i can understand that, the more i think about it the more i think i can fix this. just hold on to that tub and give it to somebody who really needs it. i just need a little more knowledge from you. when purchasing virgin poly what is a good thickness i should shoot for?
Post up some pictures of the hole you are trying to patch, we may have some better advise. buying a sheet of HDPE may make for a tough patch job due to the complex bends and ribs that are molded into the original tub.
I have a lower in excellent condition, but I'm as far away from you as the factory in Buffalo, and I bet they have a good quality second (minor imperfections).
Your links didn't work....try reading this: http://www.6x6world.com/forums/6x6-w...-pictures.html
i have three more coming
that is all i have right now
