Well had a interesting afternoon yesterday. Had the Muscateer out for a bit of a drive...-12C yesterday was not going far..
24KMH top speed on slight downhill grade 22KMH flat ground...pavement.
Had the feed fuel line blow off IP couple times and before I knew what happened dumped crapload fuel into the tub...ROFL that's ok chains neede a good lube and degrease all in one. I'm running 100% Biodiesel right now the last of what I had. Now my chains are sparkly clean
I'm seeing some flex of trans when I actuate R or L control in F or R and I've hopefully discovered from that the chain clatter I hear. I'll be careful and not over tax it till I can re-evaluate and reinforce mounts.
no heat in shop last night and today it was -3 C or bout 28 F. I did a cold start video of the machine and wow...seems to work well at that temp. I'm quite impressed how well it started actually.
For some reason the previous owner of the engine said it would not start well. Hmm...guess I know more bout diesels then?
quite decent oil pressure when cold and not bad 42 when warm...
Loading a video as I type so I'll add it in once it's all loaded up.
Today I'm going to town see about some bolts for throttle pedal and speaker wire to get my flashy lights working. Hoping to bolt my throttle pedal in...wife said NOT FOR A WHILE for cable throttle purchase..you spent enough on that thing already...to get cable pedal, and she's right I have. Thus I'll do what I can to come up with some foot feed throttle..God Bless her
Appears that all in all it is working as it should so time to refine now from my observations.
Suppose need finnish wire that winch controller box in should be simple nuff...and then a rear 12V receptacle as well, I'd sure like to add on a 5/8 VHF whip antenna for use of SAR handhelds etc while out on machine.
Thanks for reading
Thanks for reading
MUSCA TUR BOTA then eh?
I made a trip to Harbor Freight Tools in Spokane and bought a 2500lb Badlands winch for $49. and it came with the control box , rollerhead, all the 8 ga wires and a wireless remote.. It will be going on the Terra Jet that I keep. Or maybe change out the 2000lb on my flatdeck trailer.. it moans a lot when I drag big stuff on the deck..
