Originally posted by fulleraviation
View Post
vampires, asx vampire combo
GPS Reality
Fuller, thanks for testing and posting the results. I can appreciate it takes a lot of time. When we did the New Avenger Tires vs. Rawhide III's we did 7 complete 8x8 tire changes. But there is nothing like a GPS, it takes all the guesswork, speculation, and opinion out of it.
Looking forward to the spacer tests to see if it improves your performance.
Yesterday and today we had blowing and drifting snow and there was an inch or two of snow that stuck on the ground, so I didn't even take the BIGFOOT out today to get any film of the ASX's in action. I really hate being in Buffalo and I don't feel like going outside when it's 30 something degrees and windy. I'm sooooo happy that I'll be moving soon. Anyways, a couple local 6x6er's and I will be out riding as soon as the weather gets half way decent and I'll have video to share then. Until then, keep us updated on any news about the tires everyone."Looks like you have a problem with your 4 wheeler........you're missin' two wheels there"
I had the opportunity to take the Max IV with the ASX tires to a Mud Bog today. I discovered a new issue.....Not enough engine to spin the tires. As long as the mud had water in it I was fine. If I ventured into the thicker stuff, my engine would bog down and I was stuck.
I will tell you this. These tires will pull. I never really lost traction, just a winded 18 HP Vanguard.
Boy, this is getting expensive. Now I will be looking at modifing the 18 some more to get some torque. I kind of wish I still had the stock clutch to see what effect that has on putting power to the ground. I love the high speed clutch though, and posted 28 mph on the way over to the bog.Last edited by fulleraviation; 04-04-2009, 05:27 PM.2007 Max IV Hot Rodded Vanguard 18HP?
Hi-Speed Clutch, Vampire ASX, 35MPH
Hey Fuller,
Thanks for all of the updates!! IMO, the spacers will probably help your water speed.
As far as the power issue...it should not be too expensive...Meinfeld always has good low buck suggestions...maybe he will chime in??
Also, going to a red clutch spring should definitely help....and if you have a 9.25" driven clutch, going to a larger one would increase low end without affecting top end.Hammers should have warning labels.
Hey Guy's,
I installed the red spring the same time I installed the high speed clutch.
The best thing that I have done is install the high speed clutch. I wouldn't trade it for anything. With stock tires there is no problem at all. I can pull all the way to 5,000 rpms. It would be neat to see if the stock clutch performed differently. I am not sure the low gearing is any different between the clutches. I can remember having this same bogging of the engine with stock tires/stock engine/stock clutch in deep thick mud. Although not as bad.
These new "Taller and Wider" Vampire ASX tires require more power.
The way it is right now is ok. I was able to climb over an 18 inch diameter fallen tree with the whole family on board, and wet mud is still no problem.
So, I do not feel the High Speed Clutch is a mistake at all. I will just mod the engine a bit and get some more torque. I like the 18 because it is light.
Today I did some more testing. This time the front 4 tires are in the forward rolling direction, and the rears are in the reverse. With two full size adults in the front and between 2 and 3 psi in the tires I showed 1.2 mph. This setup seems easier to control.
These tires provide a much better ride, and have more traction when touching ground than believable.
I truely enjoy these tires so far, even if they lack a little when floating.
Mounted directly to the axles without spacers does cause some rubbing. Not sure if this occurs when hitting a bump or during turns. It is very slight, so anyone wanting to mount these without spacers could.
I will be posting under the engine forum soon.
Thanks,
RutLast edited by fulleraviation; 04-05-2009, 07:26 PM.2007 Max IV Hot Rodded Vanguard 18HP?
Since you have the Powerbloc argo style clutch, you could do the adjustments Rock Doctor or I have done to increase the engine rpm that the cvt operates at.. it also let's the cvt gear down easier when it get loaded. He shims a spring, and I lighten weights. His method is easier to get the effect, although for me, running 6000 has shown the weakness of the powerbloc drive clutch. The hollow phenolic pucks that hold the weights are not very sturdy. My clutch puked a 1 lb weight at 6 grand, it was not a boring moment. The pucks are 5$ a piece, I'm going to carry and replace them yearly. Bottom line, get familiar with the clutch.. I also put a couple spoonfuls of graphite powder in the spring chamber to lube the shiv bushings.
Clutch tuning can only do so much for what I'd call a high geared situation.. the spacers should help. Might be getting wet over the sides then?
I ordered them from 4 wheel parts, and they shipped direct from Interco. Make sure you are ordering the 26-13-12 and not the 26-12-12. The Interco part number is asx-04 and asx-04 I believe. There is a left part number and a right part number. They were about $600 with shipping.Originally posted by hustler25 View Postwhere did u get ur tires from and do they float and how much will they run 6 for2007 Max IV Hot Rodded Vanguard 18HP?
well back from busco and i have determined this . you all can have all those 4 wheeler tires you want . i'll keep my goodyears . best all around tires . i followed a set of them vampires all weekend long . there is NO WHERE they can go that i can't .. proven fact . and they still do not swim . robbie
R.I.P sage rogers 4 11 09 .
Did Dan have all 6 Vampire ASX tires on his machine? With all 6 ASX's on my Hustler, mine swim well and outmud the Goodyears on my Hustler. I would like to see how the hull design of the machine and different weight distributions affect the performance. I'll do actual head to head testing (also GPS water speed) since I have both ASX's and Goodyears, but I'm assuming that it won't be until later this month since there's supposed to be 6 inches of snow tonight......I'm so sick of Buffalo."Looks like you have a problem with your 4 wheeler........you're missin' two wheels there"
tires etc
OH GOODIE!!! I get to try out my Amphi-tracks tomarro!!!Originally posted by jpswift1 View PostDid Dan have all 6 Vampire ASX tires on his machine? With all 6 ASX's on my Hustler, mine swim well and outmud the Goodyears on my Hustler. I would like to see how the hull design of the machine and different weight distributions affect the performance. I'll do actual head to head testing (also GPS water speed) since I have both ASX's and Goodyears, but I'm assuming that it won't be until later this month since there's supposed to be 6 inches of snow tonight......I'm so sick of Buffalo.
With of course, my Balloon tires........
I think you're right Steve......snap some pics of it for sure. When that snow melts I'll bring down a couple sets of tires and a GPS, and we'll do some testing how they all do on the Hustler 980 in all that mud.Originally posted by Amphiman1 View PostOH GOODIE!!! I get to try out my Amphi-tracks tomarro!!!
