A1,
Great to hear from you! Welcome to the Kid Club. Do you have a PTO shaft coming out the rear of the engine to the rear wall? I have seen large alternators mounted in the rear area and run off of a pulley on the PTO shaft. A 1 wire alternator type would probably be best. I haven't done that yet but I run a 900CCA battery that I got from my son the BMW mechanic. A second battery for the winch with a splitter like an RV would also work good. I recommend a LARGE winch. Many times when you get stuck or the engine fails the tires and tracks do NOT turn as you winch unless you keep the control handle in a forward position or maybe release the pump pressure.
My only experience was the worse, when I tried to climb out of a pond at too great an angle and water came over the rear swamping the motor. I didn't have the needed tools and of course kept sliding back and with no engine! Luckily I had a 4WD truck and a 4WD tractor to use to pull it out (and a nearby son with quick response). The 4000# winch barely just kept it from sliding back but would not pull it out up the steep bank and harsh side angle that I had to pull from. Now I have a 10,000# winch on it, haven't used it yet, just getting it mounted and wired up, but I got alot smarter on where to go in and out of ponds at!
Enjoy the Kid when you get it done, sounds like it should be perfect for what you want. What part of the country is your cabin project in?
SCK
SCK
