Originally posted by rockrewls
View Post
Escargo and Adair Tracks comparison
This topic is closed.
See that's my problem, or at least one of them. I keep coming at this thing from the wrong angle. The loads you guys run almost all the time. I just think of myself in the machine or what I "might" haul. Like me you guys aren't necessarily flying around either. Makes more sense. Just try to have a little room for a camera I can wait.sigpic
our machines very seldom get to see higher speeds. If my machine couldn't go over 8-9 mph...it wouldn't affect how I need it to work in the slightest. And though other tracks perform okay if your machine is not loaded or towing/climbing significantly, things change when you start to actually do this. The 0-5 mph range is where the money is made when the going gets tough. Frequently that's all the faster you can travel anyway...even if you were on a quad in the same conditions. Sometimes it gets nasty. The elevated belt track needs far less throttle required to make your wheels turn with equivalent loads (all other things being equal....same machine/engine/clutching/gear set/tire diameter.) So the loss of top end is an absolute non-factor. I don't need to go 15+ mph. I do need the most power available at crawling speeds. I imagine most every other recreational atv/utv is faster than our machines. That's okay, because that's not why we have them. They're primarily utility-based machines (even recreational utility) at least the 8x8's for sure.
I imagine I'm telling you most of what you know already. Your tires turn faster than your track. This style track just requires less throttle and demand from the engine to actually turn the track. Exhaust temps invariably go down, less fuel is burned, operating temps will be less. We frequently drive or climb for a significant length of time under this load, so overburdening your engine can turn into a big deal. These tracks are one of many things you can do to get better performance in this area. You do go slower, yes....but not necessarily. Instead of going fast/slow fast/slow continually burdening your engine/clutches with intermittent high loads and high fuel requirements....almost like starting/stopping in 2nd gear in your car...you just loaf along instead in 1st gear..sometimes just above idle. No different than picking the right prop for your outboard, or impeller pitch for your jet, or gear ratio in your pickup truck. Ideally you want to match the load you want to push with the right gearing (or propping) to make the engine operate efficiently. Just because you can push a taller gear doesn't mean you should. Overpropping a boat is bad for example. And on our machines the clutches can only help you so much. The track just helps a little more. And, eventually, you'll need every last bit of that extra power that the track provides.
The engine is just able to multiply it's power to the track. You don't have to increase the throttle near as much. This continues to hold true even if you do increase the throttle settings as you just multiply the extra power that you are making. And, the slow crawl speed of the machine is very useful in crappy terrain too. You won't use your steering or e-brake near as much to control your speed. Just keep your clutches engage and crawl up or down anything you want.
As I'm sure you know, sometimes smaller engines pushed hard burn significantly more fuel that a larger engine that simply has to loaf along. When you have to flog your engine hard...you burn more fuel. Same concept here. Instead of flogging your engine on tracks (especially when towing or climbing...some of us actually need to do that)...loaf along on tracks instead.
And at the speeds we travel up and over all the crap we do..constantly on and off again...you're essentially asking your engine to push a taller gear on and off again as well, burning extra fuel, and giving your belt a real workout. The gear-reduction and lower power requirement of our small engines still turn the track fast enough to go where we need to go w/o working the engine hard at all. And, if you do need serious climbing power, you've just got that much more....on top of whatever mods you've done to your machine.
While I admire and respect your claim it seems contradictory to taking the word of one person along with the love and acceptance that Jesus Christ taught.Originally posted by Model Citizen View Post..sorry, but I only have one Saviour.
I don't know the inner workings of Apache Gear or the number of employees but I guess you could be the only one on their payroll.Originally posted by Model Citizen View PostI guess I'm beginning to think someone is on someone's payroll. Is it just me?
I really, really, really, have a hard time believing you read the entire thread Bridget. Here is a picture I grabbed from the Dunes thread.Originally posted by Model Citizen View PostReally appreciate reading the discussions on tracks even though they certainly aren't something that would work for us, but you guys know & understand that, don't you?
That thread has 27 pages of really cool pictures, videos and information on not only you guys having fun but sand and the what it takes to traverse it.
Man this is crazy. Here I'll post Marc's video again.
now add this
Now add a couple billion cubic feet of fine sand. It could definitely equal something that could work for you. Yes this thread is targeted at Alaska type conditions but it is full of all sorts of correlations you could form between deep powder snow and sand. It also contains a wealth of information about grousers, gear reduction, track derailment etc. Heck I'm actually really excited and I have to run to Michigan if I wanted sand dunes but this opens up that possibility. Buzz has all sorts of Hybrid ideas for tracks. Some of them have been discussed here. I would think even some one like Rock could use a little high speed scout machine at times on a hunting trip. Maybe we need to get someone more like Marc near some sand.
This thread sort of rocks. Keith.sigpic
And this is why I will not own a adair pro series track for my needs, the guy isn't even in bad stuff or loaded and he's in a 6 wheel machine to boot which is even harder to throw a track on!!
Go to the 34:15 mark of the video
Haspin 2013 Full Ride - Max's, Mudd-Ox's, Argo's - Amphibious ATV's - YouTube
Rock
For me it's just a bunch of testing I guess. First off those aren't pro series tracks, They are the older mud and snow tracks with side plates all linked with chain. Second because its a trail ride and every one with tires tends to fly around I have the tires aired down to around 4psi. Due to the fact that chain holds the tracks together they need to have a link removed occasionally. Mine were due a while ago but I wanted to see just how loose I could run them. It also should be noted the track did not come off. It twisted back undernieth and stayed on. It could be argued that dinking around and counter rotating on rutted side hills is harder on the machine than just driving in a straight line loaded I would think. I was amazed at the fact I could just drive back in them and run the rest of the day with no problems. Seems like people like to go fast on trail rides for some reason. I like to just bore around slow in the untraveled muddy spots.
Keith.sigpic
Keith, it doesn't matter if they are pro series or the chain style they are both flat track designs and, you can try to defend them all you like, they were a big problem IMO, and and the front tire came off as well.
It took a bunch of guys helping to try to get it back on to a empty 6 wheel machine, I personally find that totally unacceptable performance and something I would not own.
The elevated belt series on the other hand would likely be fine aside from the fact you would need to add additional traction enhancements.
As well tires being run at 4psi should have no bearing on the performance of a track.
Rock
Wow, it was off the front tire too? That's even more impressive to me that it drove back on and not off. I now my rubber tracks wound have just drove off or sliced my body. But I could never get away with tire pressures below 6psi with my rubber tracks. So with an Escargo track you are able to run 2-3psi in the tires? What kind of sidewall wear do you get from the steel grousers then?
Keith.sigpic
I have to chuckle at these guys that go to atv parks and run back and forth through the same mud hole or mud puddle thinking they are AATVing. I been through Wyoming, Montana, Idaho, Washington, Youkon, North West Terratorier, B.C. and now live in Alberta. In my opinion if your out off roading, not in a atv park on designated trails conditions are much the same everywhere, Downed trees, hilly terrain miles of marshy wet grass lands (moose love that!) rivers and creeks. The only real difference is north of centreal B.C./Alberta your going to see skeg and A LOT more wet marshy ground, Alaskan conditions are everywhere. Some years Alaska has more snow but then like this year we have the snow and Alaska has less. Alaskan conditions are probably better phrased off the beaten path conditions. You know,,,, where no quad has gone before.
When I go out I'm alone, no other Argos or AATV's around. Theirs lots of guys like me, Buzz and Rockrewls go places and do things atv park guys only dream of. The choice to run lower cost flat UHMW is good for some guys, it fits the budget and conditions but if your going 10-15---30-50 kilometres or maybe even more back in the boonies you NEED the best potable machine and accessories. Ox, Argo and Hydratrek make mighty fine machines ane we choose our track system accordingly. Before buying Escargo tracks I looked at all of them, looked at lots of videos and read threads on sites like this (6X6 world). Cost a little more, yes but I'm confident they will get me there and back without falling off and deliver the traction to get over downed trees, rocks and up the hills or along the side hill with the bite to get through and stay on. I can kinda understand defending a product you spent your hard earned money on but let's look at the big picture before bashing a different track because you chose the other brand.
I bought a Argo because it fit my budget and what I want it to do with it, if I had a unlimited budget I would have bought a Hydratrek. I'm not going to bash the guy that bought a mudd ox or Hydratrek because I didn't buy one, I'm a little to grown up for that!Last edited by 2014SE; 03-09-2014, 11:49 PM.sigpic
Camo side up, Rubber side down!!
2014 Argo 750HDI SE
2008 Honda Rubicon, Camo
2008 Jeep Rubicon, Black, 2 door, 6sp, 2 Warn winches.
Keith.[/QUOTE]
I've run mine at 2-3 psi plenty (on actual steel escargos) w/o any problems. The key is to make sure the belting is beveled so that it is further inboard than the steel crosser's vertical guide area. The pressed portion of the crosser (not the laser cut vertical paddle part) is smooth and rounded over so there is nothing scraping the tire sidewalls. UHMW has to have a smooth routered edge too to minimize friction.
The sidewall wear would be no different then UMHW, don't get me wrong im not against adair, their elevated track system is probably just fine like I said, but the flat track systems are all the same and they come off under what I consider very light riding conditions, I guess that's fine if you don't mind the headache, but for me that's not acceptable and maybe for others too.Originally posted by kghills View PostWow, it was off the front tire too? That's even more impressive to me that it drove back on and not off. I now my rubber tracks wound have just drove off or sliced my body. But I could never get away with tire pressures below 6psi with my rubber tracks. So with an Escargo track you are able to run 2-3psi in the tires? What kind of sidewall wear do you get from the steel grousers then?
Keith.
I mean really that vehicle in the vid was on hard pack no stumps or anything on a light 6 wheel machine when that happened that to me says volumes!!
I know one thing a properly setup elevated belt track design you can even get a flat or very low tire and still drive out and keep your track on, lets face it we don't always have air in our tires they can get punctured or leaks, I know from experience.
Rock
Pics of Escargo. I'm glad someone who has never run Escargo (or even looked at them up close) told me they are hard on my tires, I would have never known otherwise!
Sorry they loded upside down...sigpic
2014 Argo 750HDI SE
Horse Hockey!!!Originally posted by rockrewls View PostThe sidewall wear would be no different then UMHW, don't get me wrong im not against adair, their elevated track system is probably just fine like I said, but the flat track systems are all the same and they come off under what I consider very light riding conditions, I guess that's fine if you don't mind the headache, but for me that's not acceptable and maybe for others too.
Rock
It's funny that after spending days, and weeks, and months, and years, testing both the chain tracks, and the pro series, under extreme conditions in my swamp, that I have yet to slip a track. hmmmmmm, maybe 4psi isn't enough to keep a track on,go figure. Maybe you consider my swamp very light riding conditions,or maybe you haven't seen any of the videos of my swamp,but I'm guessing most people would.
So the fact there is video proof and testimony of people, for instance Keith stated in an earlier comment hes had his derail or "almost" derail at least 4 times in this forum as well others have either slipped tracks or "almost" slipped tracks specifically adair pro series or the chain sytle, under various ridding conditions its just all lies right???? someone must have spent a lot of time editing the video then it seems...lol
And yes your riding style is light compared to where I have to go and the loads I carry.
And having to make sure my tires have 6, 7 maybe more psi in them to function properly, I consider that an inferior track design not superior track design!!
lets face it argo tires can leak, get pin holes, bead leaks anytime during use and when your a long way out it a pain in the rump to have to mess around with tires and tracks that can and will fall off either due to inferior design or low tire pressure especially when your loaded.
I don't carry 4 or 5 guys around with me to lift and jocky my machine around to try to get a set of tracks back on my machine!!!
The elevated track design is superior IMO to all flat track designs, I don't care what brand you choose but the elevated track system is defiantly a better design!!
Oh and keith, at 34:42 of the video just before it cuts scenes, yes the track is off the front tire when they tried with out success to get it back on.
RockLast edited by rockrewls; 03-10-2014, 04:32 PM.
Keith, 34:42 track is off the front tire!!Originally posted by rockrewls View PostAnd this is why I will not own a adair pro series track for my needs, the guy isn't even in bad stuff or loaded and he's in a 6 wheel machine to boot which is even harder to throw a track on!!
Rock
Just wondering how much power/torque you need to run the Escargo tracks compared to the Adair tracks? I have an 02 conquest with the 20hp kawa with med gear tranny..... Would the 20hp be enough to run without taking away to much from the powerpack setup...Even if you’re on the right track, you’ll get run over if you just sit there.
—Will Rogers
